Flandy Rv-10
Date: 7-20-2010
Number of Hours: 1.50
Manual Reference: 25-3,5,7
Brief Description: Aft Center Section and Rear Spar Bulkhead
Final drilled #12 the top hole row on both gear mounts to center section. Bolted in place. Using f-drill bushing and #30 bit, match drilled all common bottom holes. Final drilled these holes #12 and checked fit of AN3 bolt in each hole. Removed gear mounts and deburred.
Clecoed the for aft center section seat rail supports together. Match drilled holes #40,#30,#19 as appropriate. Trimmed hat stiffeners per instructions Clecoed side bulkheads, seat rail supports and hat stiffeners to F-1004B center section bulkhead.
Clecoed rear spar attach bars, bulkhead side channels, crotch strap lugs, gussets, and idler arm brackets to rear spar bulkhead.
Fwd Center Assembly
Aft Center Assembly
Rear Spar Bulkhead
