Match drilled leading edge holes into A1009 counterbalance. First #40, then final drilled #30. Then drilled through spar and rib into counterbalance and marked another hole as indicated. Removed skin and final drilled the three holes in counterbalance to #27. Lastly, disassembled ribs from spar.
