Torqued all main wing bolts and checked with two different units
NAS 1309-58 bolts--960in/lbs NAS 1306-58 bolts- 180in/lbs AN6-11 rear spar - 175in/lbs with cotter key.
Threaded all cabin wires out to final location in each wing and threaded all pre-installed wing wires into cabin to be routed to final destination later.
Installed both flaps and rough filed inboard edge to allow clearance with fuselage- will need to check gap and finish install.
