Brief Description: Bellcrank angles and Longeron redo
10-10
Step 1 Clecoed F1037B+C bellcrank angles in place. Step 2 Final drilled #30 bellcrank ribs and angles and bottom four holes of baggage bulkhead channel. Step 3 Fabricated F1010B spacer from stock per plan dimensions.
10-6
Step 1 Cut new stock to 98 1/8" and deburred ends. Marked 20 11/16" for bend. Properly marked 7 7/16" by 15/32". Drilled #40 pilot hole. Final drilled to 1/4". Removed indicated material per plans and finished to smooth.
