Brief Description: Baffles Day #41 and Throttle cable
Re-installed propeller with two different length alternator belts.
Worked on reinstalling baffles.
Determined that throtttle cable needed modifications but the changes aren't easy. The bulkhead fittings were at the limit but the cable ends were too long. Decided to drill hole in aft arm and attached with rod end bearing. That seemed to work quite well.
