Flandy Rv-10
RV-10
FWF Day #16 and avionics
AoA screen was dead, so called tech support. Turns out the Internal fuse was blown. Replacement on the way.
Found out the new stick grip fits on the existing ones. Should not need to replace.
Found several fittings that had been tight in the pitot/static system were no loose. Tightened. Will recheck on monday.
Trimmed fifth mounting point from intercooler. Too close to oil line and wiring.
Fabricated new fourth mount for intercooler.
Installed intercooler.
RV-10 Home
3570
330
284
918
1411
579
