Flandy Rv-10
RV-10
FWF Day #15 and cowling
Unpickled engine per manual
Started by testing starter. Didn't work. Found blown fuse. Worked normally.
Re-installed glowplugs and tested.
Then went to work replacing the RHS high pressure fuel line due to chafing of cylinder #1 line in the test cell. CMI to finish torquing.
Had to adjust baffling and then re-installed.
Painted alternator mount parts then re-installed.
Added foam to low areas on lower cowl
RV-10 Home
3570
330
284
918
1411
579
