Flandy Rv-10
RV-10
Mount and FWF work
Rotated left aileron pushrod so that aileron trim actuator could connect properly.
Removed engine mount and nose gear for eases of installation on the following.
Drilled FW for ANL current limiter and shunt, then bolted in place. Fabricated connectors for the current limiter and shunt.
Deburred remaining engine mount holes. Drilled to correct size, grounding strap holes in straps and engine mount.
Reinstalled engine mount and torqued to 185 in/lbs. This allowed for adjustment to align cotter pin holes.
RV-10 Home
3570
330
284
918
1411
579
