Flandy Rv-10
Date:  1-23-2015
Number of Hours:  6.00
Manual Reference:  46-1
Brief Description:  Mount and more wiring
Drilled and installed nutplates on side panel of ADHARS mount for RAC 24-12volt rudder trim power converter. Routed ground and power wires to switch location.
Drilled remaining engine mount holes. Fabricated spacer for lower left bolt. Temp. installed nose gear and adjusted bolt hole opening on far left tab.
