Flandy Rv-10
Date:  1-12-2015
Number of Hours:  4.00
Brief Description:  Pitot/Static connections
Completed main Pitot and Static connections to airframe termination at sub-panel rib. Inserted AFS AOA tubing connections into main lines. Started routing of avionics pitot and static connections for Rib to unit locations.
Continued working on panel lighting connections to dimmer. Added wiring for GMC305 lighting bus connections.
