Decided that I need an additional dimmer switch. Located where it will go along with flap switch and rudder trim rocker.
Pulled panel and radio rack. Installed three pins into GTN650 P1001 connector. Lighting HI and LOW and TO/GA input. Routed lighting LO to ground and terminated. Routed Lighting HI to connection point of other lighting bus wires.
