Started off the day by making bottom rudder fairing removeable. Drilled rudder holes #27, deburred and dimpled. Drilled fairing with #6 nultplate jig. Drilled, countersunk, and riveted K1000-06 nutplates.
Also drilled a #19 drain hole in the lowest point of fairing.
Assembled passenger over light panel and wired lights to switches. Assembled center console. Had to fabricated spacer to fit under hinge to make allowance for leather covering.
Determined that my ECU mount isn't going to work exactly as I planned, so I changed the design. This version can be installed later if all goes well. Started prepping for riveting of final fuselage skin.
Needed to check some of the newly painted interior panels, so I spent some time checking fit of carpeting (needs some work) and the seats with side panels.
