Installed three adel clamps to secure the GTX23 cables. Trimmed ext. wire to correct length, stripped and crimped new pins.
Got out manual to check pin locations and discovered several didn't make sense. In fact the nomenclature on the master wire drawing was for the GTX330. Tracked down a pin out diagram for the 330 and they all matched up. Oops! Can't wait to here from Stein on this one.
Fortunately, the Gtx23 used a lot of common pins and the extra audio wires just won't get hooked up to anything.
Stress level back to normal, I stripped, crimped, assembled and installed the connector into the remote mounted case.
Crimped the connector onto the antenna cable and installed.
Tightened up the antenna and wire bundles leaving a service loop up in the cabin sidewall.
