Brief Description: Left Door Fit and more electrical
Installed nutplate for adel clamp that holds the B&C OV crowbar module for the ground power contactor.
Decided 12 volt convertor and bus fits nicely on existing shelf, so changed plans and drilled shelf for nutplates to mount both.
Continued working on left door. Cut and pointed two 5/16" -24 bolts for door pins. Tapped door rods 5/16-24 for door pin markers. Rough cut door seals to size and with them installed, began working on final fitting door frame opening.
