Brief Description: Elev. trim plug and New ELT mount
Fabricated a mount for the 9-pin AMP cpc II plug. Crimped pins to wires and inserted into plug. Wainting for warmer weather for prime and riveting of mount.
Matched drilled ELT cradle to aft deck. Deburred and installed #8 nutplates. Using 1" spacers, attached ELT cradle to aft deck leaving room for trim cables to pass underneath. Drilled one tooling hole on aft bulkhead to 1/2" for antenna mounting location.
