Started today by locating and drilling holes in cabin cover for Rosen Visors. Once mount holes were drilled, Cabin cover removed and structural filler bonded in place under a aluminum peice shaped close to visor mount to provide flat mounting surface. Once curred, body filler used to start blending mount into door post.
Moved on to wheel pants. Continued sanding main seam. Installed and worked on main attach screw installation and finished by trimming right wheel pant for tire clearance.
