Brief Description: Baggage Areas Complete- Door Mounting Cont.
Finished riveting the right passenger seat floor and installed remaining nutplates.
Match drilled nutplate patterns into F-1006 Bulkhead. Deburred all holes and dimpled #40 holes. Riveted nutplates in place. Fabricated wear blocks per plans and riveted in place on corrugated bulkhead.
Located baggage door in opening and taped in place. Match drilled door frame into hinge using modiified clecoes. Removed and C-sunk holes in hinge. Riveted hinge to frame mount.
