Brief Description: Drilled forward rail angle support
Tonight I drilled and clecoed the forward angle supports for the cockpit rail. The forward end of the angle is drilled and later bolted to the instrument panel. Then, I took on the laborious task of deburring all of the holes in the cockpit rail as well as the welded seat back support and the various plates and spacers. Later, I will dimple and countersink these parts.
This is the 816-B angle that supports the front of the cockpit rail and bolts to the instrument panel
