I finally got around to completing the second section of my build table. I was at a work stoppage with the stabilator after installing the ribs (for and aft) because the skins needed a very long, flat, surface in order to make sure everything was true and straight. I basically built two identical tables, and joined them with a set of buckles. The buckles keep them together and aligned properly. When I deploy, I can take them apart and flip one over and on top oif the other. I can then store parts under and on top of the assembly while maximizing space in the garage.
