Steves S-20 Build Site.
Date: 3-14-2019
Number of Hours: 4.00
Brief Description: Made Root Close Out Panels.
So - I had every evening over the past week scheduled for airplane projects. I spent last Sunday painting the gap seals and wing closeouts, and when I left my shop at just after midnight on Sunday night the entire building was right at 80 degrees. When I returned at 9:00 the next morning I found that several water pipes in the ceiling of my office building had frozen and burst, filling the building up with about 2 inches of water... My priorities changed and I spent the entire week working to get my building and business up and running again -- Ugh....
In the process of drying out my building, a bunch of office furniture and other items got moved into my paint booth area, so for the time being, I am unable to paint, and am working on whatever I can to get the wings ready to install on the fuselage without needing paint.
I fastened the gap seals in place. There was not enough room to get my rivet gun in place without damaging the paint, so I bent the stem of each rivet about 10 - 15 degrees, and then placed a wheel collar from my model airplane stash on the stem as a spacer while I pulled each rivet tight.
Then I started with the root end covers. When I painted my wings, I masked off one of the root ends such that some of the aluminum that didn't get painted would not be covered by the stock parts. I noticed this before I painted the opposite wing, so now I have a mis-matched set. I intended to go back and touch up the missing paint areas, but I decided it would be easier to just cover it all up, so I made some smaller plates out of 0.016" thick aluminum that will cover up the root end of the wing between the stock covers and the spars.
Determining the required geometry.
The front plates.
The rear plates.
