Steves S-20 Build Site.
Date:  3-30-2016
Number of Hours:  25.00
Brief Description:  Wiring!
I spent a several weeks wiring the avionics. I made a lot of personal notes so I can maintain the systems later, but I didn't take many pictures to document the process.
One of the most valuable items I had for the wiring was a laber that prints on heat shrink tubing, Several times I would select a section or compoent to wire, then spend some time figuring out and labeling each wire. Then the job of connecting them was easy. I have also already found the labels to be invaluable for determining the function of wires as I continue to assemble the airplane.
The only other comment I would have would be to take your time and plan ahead. neatness counts, and being able to access everything on the completed plane will save agravation in the future.
Wires behind the panel.
Labeled wires ready to be hooked up.
Labeled wires.
Labeled wires.
