Brief Description: Tapes on the Fuselage Longerons.
I installed the tapes along the upper and lower longerons.
On the upper longerons I cut some rectangles where the stabilizer mounts come through, then made a slit on the bottom side. I started at the rear getting these rectangles placed first, then worked forward.
On the lower longeron I started at the front and worked rearward, stopping at the protrusions and making cuts as needed.
I had made some templates out of index cards when determining the shape of the cutouts for items like the stabilizer mounts and rudder stop. I used these same templates to cut holes in the tapes. -- Probably overkill, but it came out nice.
