Steves S-20 Build Site.
Date: 4-19-2016
Number of Hours: 12.00
Brief Description: Covered LH Side of Fuselage.
Covered the LH side of the fuselage.
* I spent a lot of time getting everything placed so the fabric would lay down as smoothly as possible. No matter what I tried, the fabric tended to bunch up in the area of the radius at the bottom of the fin. I decided to get it as close as I could, and then glue along the bottom longeron, and then work the top into place.
* I cut holes to clear the wing strut attach, the tail brace wire mounts, and the rudder stop provisions. Using a compass I marked the fabric 3/4" wide along the bottom and cut as straight as I could, and glued in place.
* With the bottom glued, I started trimming the excess fabric off the top, leaving about 6" excess. This really helped reduce the bunching at the bottom of the fin. Using every spring clamp I own I was able to get it to lay pretty smooth, and then I glued it to the top longeron and fin working from the front to the back and removing the clamps as I went. I left the radiused section for last, which seemed to worked well.
* I didn't cut any darts, and I probably trimmed the fabric in the area of the fin radius a little short, although I am not worried about it. I think I will put a short section of bias tape in this area just to make sure I sleep like a baby...
* In the end I was thrilled with the way it turned out. I have not performed any shrinking yet except in a few small spot areas to get the fabric to lay smooth on the tube as I glued, and the fabric is relatively smooth. I will do a light shrink before I start on the other side.
* This job is bigger than it looks. I worked on it for about 12 hours straight, and with only 4 edges left to glue I just hit a wall and had to shut the lights off for the day -- I was exhausted...
* I still have to cut out and trim the windows, but I have some family coming the next couple of days, so I am taking advantage of the extra help to get the frame of the paint booth built.
Pulling the fabric into place.
Wing strut clearance cut, and the first spring clamps in place.
Completed to the stage of light shrinking.
