Added temp probe to com antenna mount, glued the sound blanket to the firewall, and riveted the boot cowl stiffeners.
Comments:
* I re-made my com antenna mount to allow room to add a hole for the Dynon temperature probe. I am expecting to locate the ADAHRS under the forward baggage area, so this location for the temperature probe will allow for short and simple wiring.
* I glued the sound blanket to the firewall using Dap Landau Cement. I was careful to line the bottom seam up with the bottom edge of the firewall, but when I trimmed the excess I found that I had trimmed off the bottom seam. This left about 2" of loose black material that was not fastened to the backing foam. I used the Landau cement to fasten this loose material.
* After removing all the boot cowl components, deburring and cleaning, I reinstalled the lower half and riveted the stiffeners and firewall angles per the manual.
Covering is up next!!
The temperature probe mounted next to the com antenna.
