Installed the air vent intake and antennas for the transponder and ADSB.
Comments:
* The air vent intakes were fit up without trouble.
* I put holes for the Transponder and ADSB antennas in bottom skin and made clearance holes in the floor board. Dynon recommends 24" between these antennas, and mine are about 25" apart with one in front of the left most pedal and the other in front of the right most pedal. The right hand location is close to the brake cylinder, but I think it will work without interference. The cylinders have mounting provisions that will allow them to be turned 90 degrees, so if there is interference, that is my plan B.
