Brief Description: Installed nose wheel steering rods
I did not like the way that the steel rods rubbed against the pass-thru sliders. I found some rod bearings that fit the rods well and allowes them to slide smoothly and easily. Nuts will be tightened down later after I make any needed adjustments.
