Randy's 750 Cruzer Project
Date:  6-9-2018
Manual Reference:  C75-WA-2
Brief Description:  Removed rivets from top skin so I can install fuel
Didn't realize I needed/wanted a fuel return line before I sealed up the top wing skins, so I drilled out the rivets on the top skin sections next to the fuel tank. I also remove the inboard trailing edge so I can drill hole in rear spar for the return fuel line.
