Steves RV-12 Web Site
Date:  2-28-2010
Number of Hours:  8.00
Brief Description:  Rear Spar and Stub Spar Prep
Spent the last week working very slowly on the rear spar, sub spar and various hinge brackets and attach angles. I knew the weather was not suitable (too cold) for painting and I spoent a few hours here and there deburring and prepping the parts for priming.
Sunday the temp got all the way up to 45F and I quickly went out and primed all of the rear spar and associated parts.
I pressed the flaperon hinge bearings into the bracket and riveted the flaperon hinge brackets.
I riveted the rear spars to the flaperon hinges, the spar doublers and the wing tip attach angles.
I riveted the stub spars to their doublers.
All in all not a bad week. Next is the long and tedious process of prepping all of the wing ribs for priming. Maybe by the end of the week, I'll get to paint again.
Rear spar and Falperon Hinges
Stub spa doublers in place
Rear spar wing tip angles
