GLENN'S WEB SITE
AirCam
2-12 Step #6
Root compression tube to rear spar
Assembled as depicted. Had to squeeze the cuff with a clamp to aligned the holes so as to get the AN43B-34A through. Also installed the wire assembly WI-101.
Holes drilled to #8
Cuff installed
1661-0619 rivets
AirCam Home
547
Ailerons
Center wing
91
229
Elevator trim tab.
Elevators
Flaps
Fuel Tanks
Horizontal Stabilize
Paint booth
Vertical Stab
