GLENN'S WEB SITE
AirCam
2-11 Step #5
Compression tube to tip bow front spar
Tip bow installed as depicted. Wi-48 compression tube installed inside the front spar and then an AN4-37A was inserted through to the compression tube WI-004
drilled to #8
Riveted with 1661- 0619
AirCam Home
547
Ailerons
Center wing
91
229
Elevator trim tab.
Elevators
Flaps
Fuel Tanks
Horizontal Stabilize
Paint booth
Vertical Stab
