Adjusted assembly as directed. Checked continuity of switch activation by stall warning vane with ohm meter. Removed clecos and left wing mid skin. Made stall warning terminal wire. Connected one end to normally open terminal on stall warning switch and routed wire through snap bushings in each nose rib to inboard rib. Connected ground wire to common terminal oon stall warning switch. Routed string through bushings in each nose rib from outboard to inboard ribs, for future wiring.
