Brief Description: Terminal Bracket Wiring and Installation
Attached connector to inboard end of wire from stall warning switch. Made one terminal ground wire. Attached terminal ends of stall warning and ground wires to terminal bracket. Installed terminal bracket on inboard rib, including fastening ground wire connector.
