Trimmed terminal brackets. Drilled and trimmed terminal blocks. Riveted terminal blocks to terminal brackets. Fabricated ground wire for stall waring micro switch. Installed stall warning subassembly. Positioned and clecoed left mid wing skin over nose ribs and stall warning sub assembly, adjustment of stall warning vane.
Terminal Brackets
Stall Warning Assembly Installed
Left mid wing skin clecoed for adjustment of stall warning micro switch
