Prepared rudder spar cap, hinge bracket, and rudder horn, and clecoed to spar. Trial fit rudder spar assembly to V-stab assembly. Space between bearing in v-stab upper hinge assembly and upper member of rudder spar upper hinge bracket is greater than anticipated. Will cherck with Van's support regarding possibly adding second washer as spacer.
