Brief Description: Aileron Trim & Throttle Quadrant
I worked on the aileron trim getting the cable completion nearer to completion. I got the cotter pins that needed to be attached to the springs and marked them and also cut them to the approximate length that they needed to be as they are way too long! It was a shorter session because other things to tend to in the day.
Then in the afternoon while doing household stuff Rob mentioned stopping by on the way home from the airport to check out the progress on the project. Of course that led to another work session for an hour before my wife and I had to leave to go to a BBQ at the neighbors....we started working on throttle quadrant cables.
Got a bit of work done on the organizing of the cables and discussing issues....so any progress is good progress in my book!
