Back in the shop after a ten day work road trip......after taking care of multiple chores-lawn,mail,etc.
I had to remove the throttle quadrant in order to get the hole drilled into the throttle arm location. I measured and drilled the location in accordance with the 1/2 inch spacing according to Vans plans. Once I got the location marked I popped the 3/16 hole in the location.
I also spent a lottle time sanding the rod to get the oxidized finish off the rod.....I think it looks better that way.
Now I have to cut the hole through the one bulkhead for the rod to pass through it.
