I took some time to basically get everything positioned and marked prior to drilling the holes for the gear brackets. I had to cut a little notch for getting the outboard brackets in place. I also took the opportunity to cut clearance for the rear bolt position.
Fitting brackets
I had to notch out the skin to get the bracket in the bay
Positioning the wear bracket and making clearance for bolt
