Completed work on Rear Spar. Drilled elevator hinge brackets. Drilled all holes for rear spar reinforcement. Assembled and drilled center elevator bearing brackets. Drilled holes in Front Spar and bent angles on center sections of fron t spars.
Began work on Front Spar Reinforcement Angles HS810 and HS814.
