I took a break from the Pass Thru's and worked on the wiring for the rear power outlet and the USB power outlets. I got the power and ground routed. I am going to pigtail the USBs to the power outlet. I am going to use a solder sleeve to do this as that is what they are designed to do. I made the labels for the wires on both ends.
I wanted to add a snap bushing for the LEMO wires routing since I decided to place the LEMO in the upper portion of the GIB bulkhead. I did that in order to keep it away from the hand area. I am probably going to run a clip or two below the cockpit rail to hold the headset wire out of the way for the GIB.
