Bob's RV-8 Build Site
Date:  1-3-2023
Number of Hours:  2.10
Brief Description:  Baffle Ignition Wire Pass-thru's
Finalized the major holes for ducting and pass thru's for ignition wires. I measured and formulated what I had to have for clearance on the ignition wire pass thru and then went to cutting the necessary holes on the right rear baffle and then the left rear baffle.
I will probably attach the pass thru's using nutplates and will drill and countersink for them but will wait until after coating to install them.
Right Side Pass thru
Left Side Pass thru
Left Side Pass thru
Clearance hole and attach holes
