I decided to work the front baffles tonight. The front baffles consist of two halves and they meet at a bracket in the middle.
Once again to avoid making scrap out of good parts, I made a posterboard template that I worked with through this session to get it to a point where I could use it to at least get a rough cut of the real baffles. It took some tweaking and a number of putting it on and off and trimming....but by the end of the session I got it close to where it needs to be.
I will use the pattern to rough out the real baffles and then use the paper clip method to establish the baffle material gap.
