Tonight I only had a few minutes to go down to the shop. I decided to make a template out of poster board for the completed left side. I will put it in the same position on the right side just to see if the profiles on both sides are close.....just a thought I had.
After making the template I took inventory of the Vans wire kit that came with the project when I bought it....basically it comes down to I need to buy a lot more wire. Either the previous owner took some out of the kit....or they give you the bear minimum. Well....that will be soon on the agenda.
