Due to the dust of sanding I went outside after work and set up to sand some of the fiberglass parts which I had applied Smooth Prime. I start carefully with 320 grit to knock down the bumps and thicker areas of the Smooth Prime. Then using 400 grit sandpaper I complete the sanding process being careful. I completed the two small wheel pant fairings...they are ready for epoxy prime.
After moving things inside I decided to apply a few more panel labels.
