Brief Description: Wheel Fairing and Upper Cowl Fiberglass
I went back to working some fiberglass areas that I was wanting to address.
I made some nylon dams to place around the oil door perimeter. I was using a sanding method that ended up being a little too aggressive and took a bit too much off the sides. So I clamped the dams in place and filled the space with SuperFil Epoxy Filler.
I also had to build up the rear edge of the right wheel fairing. So I used a dam once again and laid it along the seem and built it up with SuperFil. The buildups are maybe around 1/32 and SuperFil works great for such things.
Finally I was in the shop and decided to slip some switch covers on the toggles....it may or may not be the final color rendition but it is in the ballpark.
Filling in perimeter of oil door
Worked right wheel fairing
Installed switch condoms to promote safe switching
