After work yesterday I went out to do more sanding. I continued sanding the SuperFil on the bottom cowl and completed it.
I then wet sanded the upper cowl a bit more on saw horses outside. I then put the lower cowl on the horses and wet sanded it as well. After allowing the lower cowl to dry off well I shot the areas with fillable/sandable primer. I will sand it tomorrow and see if the weather will cooperate to put another coat of primer on the cowls.
Stewart really did a great job of getting me the next can of primer, I called and spoke to Nichole on Monday.....the primer arrived on Wednesday!! They are a good company and I like the waterbourne product.
