I started by sanding the SuperFil off of the empennage fairing in the spots that needed filling. I then cleaned the fairing and used the high build primer and shot it with primer.
While allowing the empennage fairing to dry, I went back to the other fairings that I primed yesterday and wet sanded the whole lot with 400 grit sandpaper.
After getting all the wet sanding done I found the imperfections on the various fairings and once again filled them with SuperFil.
I basically have the landing gear fairings to prime, along with the cowls and the wingtips. Getting closer inch by inch.
