Bob's RV-8 Build Site
Date:  3-2-2024
Number of Hours:  4.40
Brief Description:  Lots of Sanding Fairings
Not much exciting on the log today just a LOT of sanding followed by more sanding and concluding with more sanding. I really do love Smooth Prime. I like using the SuperFil to get the imperfections in the surfaces of the fiberglass filled along with any contouring that needs to be done as well. And then the Smooth Prime really knocks out the pin holes that fiberglass is so notorious for having to deal with prior to painting.
Anyway the weather turned out better in the afternoon so I set up outside and sanded for several hours while listening to Casey Casem's Top 40 countdown from 1977.
I was able to stick on a couple labels during the course of this session as well.
Gear Intersection Fairings
VS & HS Fairings
VS & HS Fairings
A little labeling
A little labeling
