Bob's RV-8 Build Site
Date:  2-21-2024
Number of Hours:  1.80
Brief Description:  Vertical Stab Fairing and Oil Door
Went out again tonight and decided to start working the vertical stab fairing where I laid some micro. I used a large plastic trash bag to tape and fold to produce troughs that would keep the water of the horizontal stabs as I prefer to wet sand when able......the plastic bag worked good and the gritty water fell to the floor. I got a lot of it worked but it still needs more sanding.
I went inside to lay more SuperFil to the couple areas of the oil door perimeter that needed attention on the gaps for the perimeter. I think this should be the last of the filler (hopefully} so I can call it good.
One of the things I purchased to help me on both the fiberglass and some metal work is a set of riffler files. I used to use these in my machining day of working in a shop making plastic injection molds. They are used in moldmaking and tool & die making. They have various shapes and curves. A good set will cost several hundres dollars. Well I don't need a good set as I am not using it for dies and molds, so I found a set on Amazon for $50 that I can use for shaping the fiberglass and the set actually works well. I have been using them to help shape the fiberglass contours especially for the oil door but other things as well......worth the investment.
Sanding vertical stab fairing
Build up on left lower edge and right side lower edge
Riffler File Set
Riffler File Set
