I got back on the empennage fairing tonight. After modifying the curves and lines on the left HS I went and made the same on the right side.
I pulled the fairing off and trimmed the fairing to all the cut lines I drew while leaving a little extra for sanding. Once I get it sanded down some I will add more glass to a couple areas and after will use some micro to fill the places where there are small gaps on the fairing flanges.
