I wanted to work on the forward baggage door tonight and continue to get that towards completion. When I installed it the key wouldn't turn all the way to lock. Seems like all the fiddling with final riveting and what not made things move and shift a little so I worked on the rear rod that seemed to be hanging up. Using files and emory cloth I got it to close but I may give it a bit more tweaking before calling it done....will revisit it in the days ahead.
I also took time to spray the tail wheel stinger and receptacle with another coat of paint....used flat black this time.
